oil leak around bell housing
Chipw
- North Georgia
- 1980 CJ7. Iron Duke 4cyl., SR4, Dana300, Dana 30 with aussie locker, AMC 20 with detroit locker and 4.88 gearing, welded and trussed axle housing, one piece axles. 33x12.5 tires
1980 CJ7 with 4 cyclinder attached to what i think is an SR4 Transmission . drives and shifts good but im leaking oil from where the engine attaches to the beel housing. their is a missing bolt(visible in picture) that i will replace before driving again but is there more i need to do to stop the leak?
amount of oil after 2 days parked. second puddle. I assume the first couple drops are power steering fluid.
also,
this hole on the driver side of engine block seems to be leaking oil as well. I have no idea what it is. It may just be oil from the leak around the bell housing but it seems like something was attached there at some point. Any ideas?
also,
