Oil Leak but not loosing any oil!!
ChrisF
Midwest
77 CJ7 258/6 stocker
I have a dilemma.
I have a 77 CJ7 AMC 258 i6 / 4.2l . There has been a pretty good oil leak over the last 2 months.
I replaced the valve cover gasket, and I am sure it is not coming from there.
Here's the scenario..
After I drive it, there will be 3 puddles in several different spots, snd they appear pretty quick, (within 30-45 minutes).
The part I can't figure out is when I check the oil level (dipstick), it is always full.
The oil pressure is good, and it seems to be running fine.
Any ideas on what is going on??
have you checked the oil level in the Transmission , t/c and diff?
power steering fluid?
brake fluid?
antifreeze?
FYI all of these have/do leak in mine :)
Clever neighbor leaving mini-puddles in your parking spot to drive you nuts, maybe?
All CJ's seem to leak something, no matter how hard we try to eliminate them.
good luck.:)
