Engine Oil Leaking from .. ? (oil pump?)
ColoradoDerek
Good Day!!
Everything went well with my first oil change, except, now I've noticed this device is leaking oil (2 pictures called "unsure") and I'm unsure what that device is and how easy it would be to get it to stop leaking oil. I haven't explored it enough to know exactly where it's leaking from on the device. I'm just trying to get all my leaks plugged up
The other picture (heater_tubes.jpg) is of my passenger side engine bay and I have put red and yellow arrows pointing to 2 tubes that seem to go into what I believe is my heater (?) which is under my glove box kind of and my question is, can I just disconnect those tubes from the heater (or whatever they are connected to) and just connect them to each other? or are they important.
Thank you!
Thank you!
