    To dismiss this notice
    click the top right X.
Oil pressure needle vibrates / fluctuate a bit
carmd1
Florida
1983 CJ7 4 WD, AMC 6 Cylinder Motor
Dana 20 Rear, Dana 300 Transfer case T-5 manual Transmission
I have replaced the Oil pressure sending unit to the OEM unit. I notice that while I’m idle the needle fluctuates or vibrates a bit. Just want to make sure it is ok and it is not a faulty oil pressure gauge.
If its still the factory gauge that's what Id expect. Thats why you see new gauges advertising both "air core" and liquid filled.
$100.00
  50.0%
