    Thank you for your support!
Old man emu lift kit
Orky
CANTON
'80 CJ7, 304
As I start looking at my CJ7 , I am wondering how good is the old man emu lift kit. It is pretty stiff as I'm getting familiar with this car. Thoughts?
From everything I have heard their YJ conversion spring kit is a really nice spring package, I am building mine with stock YJ springs, if my tires rub on my body the old man 2.5 lift springs will be the ones I get.
I run OME heavy's with an extra main spring and its still a softer ride than it was with OEM springs. What shocks are you running?
Take your shocks off and test drive before you blame the springs.
Also-Spray the spring packs heavy, with silicon spray to help with the ride.
At what torque did you set your shackle bolts?
The shocks are also emu, and after spending 3 hours on the trail yesterday, i had no issues. Overall the suspension worked beautifully. Thanks for the input and now will focus my energy in understanding why the temp gauge remains on high
