OME Lift ?'s involving wider leafs etc
j0114
birmingham
86 CJ7 Laredo Black
The Jeep was totally gone thru, 124k original miles on body,
New Crate engine and Trans, Weber Carb, Interior replaced back to stock, Dana 44 Rear, Dana 35 Front, 2.5 " Suspension Lift 1" body 33-12.50 Tires on Mickey Thompson Wheels, New Dupont Paint
I have a 2.5 in lift on my CJ right now, its an 86 if that matters, and I was reading about OME having a kit that allows you to use the wider YJ style leaf springs for better on-road handling etc,
I plan on installing some aftermarket sway bars also.
Does anyone know anything about this OME kit or advice for better onroad handling etc.
I had wanted a CJ for a long time but it had been a long time since i was riding in one much and realized real quick how much better a TJ handled on the road
Im not going to be wheeling this CJ into anything rough so if the kit limits some of the off road capabilities I could live with that.
From what I was told the OME conversion kit was stock height, so would I need a YJ OME lift to go with the conversion kit. The conversion kit may give you options, i havent looked into it too much as I wanted to know if it was going to help at all first
