One piece axle leaking gear oil
Cj7355
I recently noticed while laying under my jeep that there was oil on the inside of the rear tire, pulled the tire off and the brake shoes and backing plate were covered in oil. So i then unbolted the backing plate and pulled the axle out, the tube had oil in it. It had an inner seal in the axle tube followed by a spacer and what looks to be a bearing race pressed into the end of the axle tube. My question is, is the bearing lubed by the gear oil? If so why is there a seal in the inside of the axle tube? I’m stumped and i can’t find any good info on this. The bearingm on the shaft is also a “cone” style bearing which is different from any other lits I’ve seen.Any help would be appreciated
