One piece hub and rotor or two
jpeck71
- Media
- 3
- Chatham, IL
- 1978 CJ5 258 6cyl - 3sp T-150 - Dana20 TC - 2.5 inch spring lift - PO body lift - stock axles - 2bbl Intake and Holley 2300 carb - glasspack muffler - 31x10.5x15
So I took the hub and rotor off my 78 CJ5 and it looks like this:
My local shop says no way they can fix that. So I need new hubs and rotors. My 78 has the one piece hub and rotor assembly and the 6 bolt steering knuckle and caliper connection. I think I can get a replacement from the same shop for about $66. Its been hard to find a place online that can meet that, but it looks like I found a set on 4wheelparts that is a 2 piece hub and rotor for about the same price, a little less actually. My service manual of course says that they are a one piece assembly. Has anyone used the 2 piece on a 78? Would there be any problems? As far as I can tell this would be a good replacement part set.
Here's the link for the part:
Crown Automotive Part 5356183R - Front Brake Rotor - Fits 1976 to 1978 CJ - 4 Wheel Parts
