onepiece convertion
onepiece convertion
Hakan
Sweden
-80 cj7
onepiece conversion
Hi!
I have a AMC20 narrowtrac with traclock carrier and powertrax noslip installed.Last weekend i broke my axle shaft. so now i was thinking about doing a onepiece conversion but i have seen somewhere that it`s not possible to do.Does anyone know what the issue is
// Håkan
Re: onepiece conversion
Hi!
// Håkan
Håkan, I put Superiors into my 1980 CJ7 three years ago. Before I could order the axle set, I had to send the company some measurements. They take their axles (and their reputation) seriously.
So do the Moser people.
Here above is the Moser web link; bring your questions to tech support and I betcha you'll quickly find out what you need to know.
I see on the 'Net that Superior Axle and Gear have gone out of business;
" Superior 1 piece axles bearing kit unavailable.
Hello I went to order a bearing kit,Superior part# EV20KIT, for my superior 1 piece axles on my AMC20 axle and it appears they are unavailable. It looks like superior went out of business. I tried the phone number on the website and I just get a constant busy signal. I also went by the address on the website since I was in the area anyways. There is a new business at this site and the man working there said superior used to be there.
What are my options now. I just have the bare axle shafts and empty axle housing ends. I cut the old bearings off the shafts. The kit was supposed to have an inner seal, outer seal, retainer ring, bearing, and a spacer. Im not sure what bearings, spacers, and retainers will work. I guess worst case, I could buy another set of axle shafts. thanks Ray "
You might query NOVAK CONVERSIONS. They are a reputable company.
Bonne chance
