Opinions on alignment - Jeep Lean
jamesweed
- Orlando, FL.
- '85 cj-7, 258, T-5, dana 300, stock diffs; 1967 Chevy Nova 2d HT
I just renewed all of my tie rods, and ends.
MY jeep has the Cj lean, which I pretty much gave up on trying to fix. However it seems that its throwing off ability to check the alignment. The jeep is definitely heavier on the drivers side, both leaf springs are compressed more than on the pass side. Distance from spring perch bolt head center to lower shackle bolt head center is greater than on the pass side. I'm convinced that the front and rear axles are not parallel to each other due to the lean. I have to compensate by always steering a little left to go straight down the road. So when i drive straight in to my driveway, stop, and eyeball the sidewalls of the tires front to back, on drivers side I'm lining up with the center tread of rear tire, on passenger side, I cant even see the rear tire.
No need in talking about fixing the lean, trust me I've tried and measured everything.
Just would like some opinions on what to do with the alignment. Id like to hold the steering wheel, AND steering gearbox straight to go straight. As it sits now, my steering wheel and gearbox are aligned with each other. Both center at the same time.
My Jeep has always handled this way, Before and after my tie rod change.
My jeep is all stock suspension, no lifts, or aftermarket shackles, springs..
Thanks!
Thanks!
