    Thank you for your support!
Misc. Option code P at the end?
Tugboat1
new york
79 cj7
Hello,
I recently started building a 79 CJ7 . The body was too far gone so i found a replacement tub that's in decent shape. I was going to build the jeep back to factory specs for the tub I originally had. But after looking at the firewall tag on the new tub, I was wondering if this was more than a base model because I cant find any option code with a p at the end.
The vin for the tub indicates its a 1978 CJ7
6v for paint and option code 3CKP
Does anyone know what the P indicates?
3 weeks, 5 days, 18 hours, 9 minutes, 20 seconds
