Paint Prep for Fiberglass Bodies
Tim
Minneapolis, MN
1983 CJ7 258 i6 with the 4 speed manual
wet sand with 400 grit sand paper clean all oil residue and prime it assuming you have no dents to fill
Also just so you know, where gloves, a respirator (if dry sanding) and long sleeves unless you wanna itch for a couple days.
I just sanded mine down with 400 grit and then cleaned it with mineral spirits at the painters shop. The factory gel coat was good enough for him to have a solid base.
Wet sanded mine with 400, wiped it down with clear water, then wiped it down twice with thinner to remove any oil. Then primed it with a 2 part primer, and shot the top coat. I had a custom color made in PPG Concept paint. It's a little pliable. I had a Vette shop recommend it for fiberglass.
Any pics? I'd like to see it.
