Passenger steering knuckle leak?
Preacher Boy
- Dallas, Or
- 1962-CJ6 (4 cylinder) Tranny a T-90 with a splitter and T-case is a DANA 18.
Ok not sure if this is suppose to happen or not, but had to take the whole brake assembly off my 62 CJ6 to do some repairs. As I pulled the bottom two bolts off the backing plate, I am assuming, some kind of gear oil from the knuckle oozed out onto the ground. Probably only about a half cup worth. Anyway, is this seperate oil from the front axle and should the oil be coming from those bolts or should I be looking for a bad gasket?
