Pcv valve = oil leak ?
RedDog
- Media
- 11
- Canton, TX
- 1982 CJ7 - Stock until my pocket gets bigger!
258 I6, T4 Trans, D300 Transfer, AMC 20, Dana 30.
My Jeep has the TEE type PCV Valve, one end is connected to the Valve Cover and the other end it just there open.
If you plug the open end, the engine quites down and seems to run better, and also has better throttle response.
Opened it runs ok, but it does want to "Stall" with the first bit of throttle, but once past that first half a inch of trottle its fine.
This weekend I decided to go ahead an plug the open end. I drove it and it ran fine, i could even take off in 1st with just the clutch, not giving it gas and idle around, so I thought, that's it... that has been my problem this whole time.... Well after driving to the next town to Lowe's I came back out to the parking lot to find a huge oil spot under the jeep.... I said well it's time to change the gaskets for sure now.
Then when I got home, after a bit I went out there and the same thing... huge oil spots under the Jeep.
Am I building up too much pressure with the PCV Valve plugged off? and it is making oil leak worse? How is everybody else's set up?
I know originally that the open end was ran to the charcoil canister... but that is non-exsitant on mine anymore, I dont have any emissions..etc.
Any Idea on this?
let me know
Thank you -
Any Idea on this?
let me know
Thank you -
