Should be interesting. Neighbors welder did not like the 1/2"
Dana 44 axle tube. Weld looked great but needed to remove one bacause rotate wrong way, spingover/under and on back of hitch rack get confusing.
After seeing the above... Wish I put under CJ to see where the transfer and axle pinion POINT.
Looks like if both horizontal... good.
If we rotate the pinion up, the
Transmission / transfer should point more down the same amount. That right?
I pointed pinion up 5 deg and is what the perch mfg suggested. Will be fun to see if he was right. I have a
T-18 with 3/4" of shims to lower
Transmission like / similar to stock. Might be 5/8 got look. Stock is 1". So I might be adding more shims for between the skid plate and the frame to lower/point the
Transmission /transf down.
I will guess summary..
1.. point up pinion and point down
Transmission equal deg from horizontal.
2... If you can point the rear pinion directly at the
Transmission /transf output..... this will work well, but a CV joint will need to be used at the
Transmission /transfer
I hope to be lucky on this one....
Fred
I will be raising pinion up 5 deg from stock WELL ITS WELDED ALREADY, iF NEED will be Lowering
T-18 with the frame/skid additional shims may tilt down
Transmission 3 deg or so???
How many degrees can pinion &
Transmission differ that it does not shake at hwy speed??
