Pitman arm bolt
Pitman arm bolt
Germy
Full Time Jeeper
Cincinnati, Ohio
1985 jeep cj7 360 20 rear and 30 front w/warn lockers 5 speed tranny,
1971 dodge dart built 318
The nut holding the pitman to the box is not tight enough, the arm is moving a little causing slop. Does anyone know the socket size of this nut? I am going to round it with pliers!
The nut 1 5/16". Torque spec is 185 ft/lbs. You need a long cheater bar or impact wrench.
Thank you! Got a socket then realized it was 3/4 drive. Hopefully my neighbor has a ratchet that big!!!
If all else fails a pipe wrench will do wonders to fit and not round over the edges. That is what I always use to remove the pitman arm bolt along with a long cheater bar.
Got a 3/4 to 1/2 adaptor tightened her up then took back the tools. Am I a bad person?
Maybe! Working on a Jeep you always need tools! You might need those same tools down the road!
