Power brake booster help
TheDirtyCJ
Mesa,AZ
1983 CJ7 -258 cid strt 6. I did the 4.0 head swap #7120 casting head ported & polished, Offenhauser manifold, Holley truck avenger carb 4BBL jetted down to 270 cfi, Pacesetter headers, Magniflow exaust,Be Cool aluminum radiator w/ flocooler water pump, Powermaster HO alternator- TFI Juicebox ignition upgrade, 6" lift ,37 inch TrXus R/T tires, Superior one-piece chrome moly axles on dana 20 rear. 4.56 gear ratio, custom front quarter panel fenders done by me, 6" GENRIGHT rear tube fenders, Warn Dualforce 9500 winch mounted on Warn front stubby bumper, Olympic reverse nerfs, Corbeau Baja XRS seats w/ 4 point retractable seat belts and Hela Baja lighting. CB radio with P.A. Tube cage doors
Does anyone know if there is a complete kit (booster/master cylinder) that would fit a stock 83' CJ7 drum/disk. I don't know what size bore I have-I've been told its 1" with an 8" booster would fit but I dont know. does anyone have the correct info? I see them from 9" down 6" with single or dual diaphragm. the bore on the master cylinder 1" and up? If any one can tell me exactly what to get with any extras I may need- I would appreciate it immensely! I want to pull the old master and replace it with the new correct set-up, Thanks everyone.
I pulled a setup from a 05 TJ that will be going in this weekend and the brake lines on the mc are on the same side as the cj.
Thanks guys, but I want to by new and have it installed by the Colorado trip.
I believe both collins bros. and parts mike sell the complete set-up.
wow, $250 is a good price on that. MORE's setup is $350. this is next on my upgrade list for sure. thanks old dog
Here's another one I just purchased for the wifes 78 CJ7 . Go to brake section and i got the 250 . It has a adjustable pedal rod set up also to take the slop out of factory pedal .The Jeep Guy Home Page
