Help Power Brake Install
JPop
New to the forum here.
I have owned a 1983 CJ7 with Small Block Chevy just over 2 years. Replaced Transmission with a Muncie SM465 little more than a year ago.
I am upgrading the manual brakes to power brakes. Have a couple questions.
1. Currently 2 brake lines on master cylinder that go down to what looks like a proportioning valve on frame rail under driver side. The new master cylinder has 4 ports but also came with 2 plugs. I assume I can just plug the 2 unused ports? When would I use all four ports on the master cylinder? If I had disc brakes on all four wheels?
2. Vacuum source. Seems to be a vacuum line between valve cover and holley carb; likely for vacuum advance. Could I tap into this?
Thanks in Advance!
Thanks in Advance!
