Power or no power brakes?
GoldenEagle36
- Media
- 54
- SW Pennsylvania
- 1977 cj7 Golden Eagle 304,automatic, Quadra-trac, full restoration just "finished." 4 inch superlift, lift shackles in the front, sitting on some KM2 Mud terrians
1999 tj 4 cylinder ax5 trans 3 inches lift 31s
1956 Dj3a all original except axles and engine, Hurricane 4 cyl. 4x4 conversion, 27,500 original miles 58 Jeep-A-Trench cj5 8000 miles.
i just built my 77 cj back up to its glory but had to use a 79 tub (14,000 mils you cant go wrong) anyway the 79 tub has power brakes but my 77 tub had manual brakes. quadratec states that their boosters only work from 82 and up. the brakes work on this one but the pedal is like 2-3 inches from the floor, and theres no grab on the way down... so i know the booster isnt working.... should i just run a regular master cylinder and forget the power or do i have to have power because i have disc brakes in the front?
