Power steer line help
defibvt
- AZ
- 1974 CJ5, 4.0L stroker from a 91 XJ,T-18 w/ granny gear, Dana 300 w/ Lomax 4:1 gears.
So, at long last my 4.0L XJ motor is in the CJ5 to stay. I have mounted all the accessory brackets i.e. a//c, alternator, and power steering. The power steering gearbox and pump came from a 91 XJ. The problem I am having is finding power steering lines that are long enough and will fit. The 91 XJ high pressure line is about 10" short. The return line is not an issue. Does anyone have a part number for something that will work or do you another solution?
