Power steering bracket and pump for 360
FiNorman
Lifetime Supporter
Orlando, FL
1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
I'm in the process of putting the 360 together with some upgrades (like the Bulltear serpentine belt system).
I need a little guidance on the bracket for the power steering pump. I now realize my AMC 258 i6 / 4.2l bracket will not work, and have found a couple of brackets on ebay.
there is one being sold that has just one bracket and one that has three brackets. which one do I need? Below are two of the brackets being sold on Ebay.
I think I can reuse my power steering pump but it might make more sense to install a new one... any suggestions on a pump that is polished? I see some different pumps at summit, but can't tell if they will fit my application. They look very different and I'm not able to tell if they are just the pump without the reservoir.
Any help is greatly appreciated.
If you notice the wholes in your first picture. If you flip over the large piece in the second picture it is the same piece. The second is what you need I believe. Has adjuster. You can see the 1/2 ratchet hole to pull tight on the steel piece to the right. I don't know about the bull tear belt kit though. Will it replace the adjuster?
Sent from my SM-N900V using Tapatalk
picture 2 is it.
