power steering not working at idle
The power steering on my CJ7 has stopped working when engine is at idle but does ok with higher RPM. I drained, flushed, installed an inline filter and bleed air out of system, but still same problem. What do you guys think? I'm thinking possibly the pump has gone bad.
For fluid, I put in a bottle of power steering fluid and topped off with ATF (Mercron, I think). Used ATF in other vehicles for years. I mainly used it on this one for the cleaning properties of ATF. As far as the filter goes, yeah, might be a bit of overkill, but I thought if it does have crud in the system it'll be filtered out. This filter can be disassembled and cleaned, it has metal mesh screen. I guess I'll drive it till the weekend and if it doesn't cure itself, I'll put in a new pump. Thanks
