Power Steering Pump bracket DIY Kit or Plans???
bgauweiler
Has anyone found a source for the brackets needed to mount the power steering pump as a DIY (you weld it) kit or plans? The eBay sources are getting pretty costly for what it is you are buying, seems like someone could put together the needed components as a kit for much less...
Thank in advance for your input/feedback.
