power steering pump bracket with 4.0 head swap
jmbridges
Birmingham, Al
1981 cj7, amc 258, t176, Dana 30
Solution
My bracket cleared the stock 4.0 manifold with room to spare, so can't help with that part.
To add height to the bracket, since the 4.0 head is taller, I bolted up the bracket and then bolted a 1/2" (IIRC) to the intake, marked them, cut some off of both where they overlapped, then welded the washer to the bracket. I did tack them together when i did the last test fit.
The lower intake bolt hole was moved and isn't a "complete" hole, but a washer with the bolt keeps it in place no problems.
I cut/notched mine as needed with a sawzall and cleaned it up with an angle grinder.
Solution
Nice looking engine! I am new on here and doing the head swap on my 1980 CJ7 . Can i ask what header your using?
I used a OEM factory header from a mid 90's Cherokee.
You'll like it, noticeable difference!
I have the 4.0 head casting 7120 rebuilt and ready. I just seen that my 1980 stock intake has the thick flange where the washers mount with the header. I need to find something newer or brake the bank with a clifford. I have a weber 38/38 so need the clifford adaptor also. Quite a project just getting everything together. I hope my rocker arms and assembly will work from the AMC 258 i6 / 4.2l along with my 4.2 pushrods. I have heard some say yes it will work and some say no.
My push rods and rockers worked fine. I'm running MPI, so the intake/exhaust were a non issue ;)
