Power steering, would this part work?
You can locate one of the basic Saginaw "800" series power steering boxes in one of these vehicles:
1964-'76 AMC
1961-'79 Cadillac, including
1963-'79 Eldorado
1964-'79 Buick and Pontiac full-size cars and Riviera
1973-'79 Regal
1975-'79 Skyhawk, Seville, Monza and Starfire
1965-'79 Chevrolet full-size cars
1967-'79 Camaro and 1968-'76 Nova
1968-'79 Firebird
1964-'79 Chevelle, Cutlass, GTO, Grand Prix, Lemans, Ventura and Tempest
1971-'76 Vega and 1975 Pontiac Astre
1960-'79 Oldsmobile full-size cars including 1966-'76 Tornado
1971-'79 Jeep Cherokee, Wagoneer, Gladiator and J-series pickups
1972-'81 International Scout and Traveler
I know this is an older post, but I found an 89 wagoneer with a complete p/s setup. Will this work for my 76 CJ5 ? The owner said it is all factory parts and it is all clean. Looks to mount the same but will the steering be too fast?
Should turn right and bolt right up but you need to check how the steering rod mounts to the box. Cj's used a "bell" connector and Waggies used a Rag joint with 2 bolts.. knda like a flat axle flange. I think that you can grab the shaft from the colum to the box and I think it would bolt up. But 89 is alot older then what in use to working with. those are the common problems with doing a earlier swap. Also you will need to use the CJ pitman arm.
