Pro Comp Pro Runner Shocks
Im Not Spam
News Posting Bot
PC Runners
Pro Comp is proud to introduce the new line of Pro Runner™ and Pro Runner SS™ monotube shocks. These high performance shocks are engineered specifically for late model trucks, Jeeps® and SUVs.
At the heart of these shocks is a gas charged monotube design that delivers superior performance compared to traditional twin tube shocks. Each shock features a 14mm hardened chrome shaft, a heavy duty oil seal pack, 2” diameter shock body that is brushed, zinc plated and clear coated for lasting performance and OE style rubber bushings.
All Pro Runner™ shocks are calibrated for each vehicle application using Pro Comp’s exclusive Vehicle Specific Ride Tuning (VSRT™) The result is multi stage valving to optimize the ride and handling characteristics for each application.
Pro Runner SS™ height adjustable spring seat monotube shocks are designed specifically for late model trucks equipped with coilover strut-style independent front suspensions. What makes the Pro Runner SS™ unique from other spring seat shocks is Pro Comp’s patent pending 180ºSS™ height adjustable collar. This Pro Comp exclusive feature gives owners the option of raising the front of their vehicle up to 2.75” (depending on application) to clear larger tires or keep the vehicle at stock height.
The CNC machined T-6061 height adjustable collar is simply inverted during installation to switch from a lifted to stock height. Owners can upgrade from the Standard Machined Finish to anodized Red, Blue or Black for a more personalized, bad-*** look!
All Pro Runner™ monotube shocks are backed with by the Pro Comp Promise Lifetime Warranty and a 90 Day Ride Guarantee. If you are not 100% satisfied with the ride on these shocks in the first 90 days, you can return them for a refund.
Whether you are towing a trailer or hitting woops in the desert, you can count on Pro Comp Pro Runner™ shocks to give you the confidence behind the wheel.
Available for most popular applications including F150, Super Duty, Silverado, 2500HD, Ram, Tundra, Wrangler and more.
Source:
Pro Comp
400 W. Artesia Blvd.
Compton, CA 90220
800.776.0767
www.ProCompUSA.com
Pro Comp Pro Runner Shocks | Digg It | Add to del.icio.us
More...
PC Runners
Source:
Pro Comp
Compton, CA 90220
800.776.0767
www.ProCompUSA.com
More...
