Pro Comp replacment spring
ftwflh
Crossville,IL
1976 CJ 5, 232 6cyl 3spd lots of rust,good frame,Dana 44s w/373 gears,ProComp 4in lift kit
I bent a ProComp spring and need to find the best place to get one.It is a 4in lift part number 51412.
Hope you were having fun when you bent it.
Not sure how I bent it but that wasnt the only thing messed up.Knocked a hole in the oil filter crossing a ditch.Had a buddy bring me my old used filter and some oil to get it home.:(
Sounds like you are out using it for what it was built for. And I bet you had a big smile on your face doing it. This is why most of us own them. :notworthy:
I'm looking to install a lift on my CJ and have always been interested in the PC 4" lift. How do you like it? do you have a SYE or shims in the back? TC lowering kit? Any info is appreciated. HOpe you got your bent spring taken care of...
Kit was on Jeep when I got it.But it came with the shims and everything.It rides rough but does ok.Be sure ALL the other parts in your suspension and steering are in good shape.
sounds like that's the general consensus that the 4 inchers ride rough. I'm still not sure I want quite that much lift. A good friend of mine commented about some drivers that they had more lift than brains and with 4 inches over stock, I'm afraid I might be dangerously close :D...I also really want to continue to be able to get it into the garage so some measurements need to be made. Appreciate the feedback though.
Found more bad parts.The shock o the left side is bent all to heck.Looks like it has been like that a while:( Got a new set on the way
Got shocks friday.....wrong ones:( return and get right ones......be here next week:)
More bad parts found.........got new spring mount plates ordered.Shock mount pin bent a wore half way off.
