problem with t18 reverse switch 1970 cj5
buck toenges
- ft wayne indiana
- 1970 cj5 v6 t18,1967 cj6 v6 t14,(2) 1953 cj3b 4cyl t90 tranny,1971 jeep commando v6 t14 tranny, Had 1964 fc150, had 1960 fc 170,1990 grand wagoneer 360 auto,
1967 scout 800 192 4 cyl t98, 1977 scout II 304 auto,
1970 toyota fj40, 1952 M37 dodge weapons carrier
I have a T-18 tranny that has an opening for the reverse light switch in the horizonal bossing by the driver side. There are 3 bossing in the back of the tranny right below the top cover facing toward the rear, The problem is that the reverse switch I got for it is way too small and will not screw in properly. It looks like I need and adapter or a different switch in order to have the switch work. I have put a rod in and felt the reverse gear actuate but it would not actuate my switch because it is too short. The reverse gear is up and toward 3 gear. Is there an adapter or another switch that would work. It looks as if the threaded hole is about 3/4" wide which just about swallows the switch I got for a T-18 jeep.
Thanks,
Buck
Thanks,
Buck
