PS done but not so great
existentialhandyman
- Media
- 14
- Northern Michigan
- 1966 CJ6 Tuxedo Park Mark IV, 225 v6 3 spd on the floor, Front axel dana 27A, single lever 2 spd transfer
TPM4 CJ6a has PS, Saginaw steering gear ID'ed to be a buick donor and the pump is a hellatious leaker.
Decent fabrication from what I can tell but first Jeep so not quite sure.
Sits above the frame not behind it like the AA style and they whacked the grill to do it, steering shaft actually runs through it.
Since it is a 225 v6 and the heater stays - 2 issues, well 3.
1. What to do about leaking bastardized manifold on the drivers bank and does the AA setup help with this for clearance. I saw Herb's earlier and Im not sure mounting steering unit behind the cross member would work here.
2. is PS really THAT much better ? or should I consider
a. manual Saginaw and from what donor.
b. go back to a stock Ross system - most posts seem to say heck NO here.
3. a better suggestion.
