Pulled leaves from RC 4" lift
Alex Kapparos
- Media
- 1
- Southport, NC
- 1978 CJ 5 304 3 spd stock everything for now
I have been reading a lot of threads about pulling leaves to soften ride quality so I did it myself this week. I have a RC 4" and the rears would make my kidneys bleed after a little bumpy riding. I pulled the bottom flat spring and decided to pull the HEAVY arch spring that was the third one up. I put the second one up back in the pack and bolted everything back together with new bushings on all four corners. I left the front springs alone other than the new bushings. The ride is AMAZING!! Very soft and the Jeep doesn't want to change direction as often as before (probably because I'm not hanging on to the steering wheel for dear life whenever I go over a pebble). The rear does seem to be fractionally lower than the front now due to a little less arch but isn't really noticible unless you really stare at it. If that is an issue for you, I guess you could use a 1/2" lift shackle in the rear or pull a single leaf from the front (I may do that).
I hope this helps out. I would recommend it to anyone looking for a little more comfort and flex.
I measured flex before the swap and will measure again and post any difference.
