Pulse air injection system?
Bensjeeping
Cortez
1984 CJ7 five speed. I just bought this jeep and its my first CJ. I've been a Cherokee guy in the past but wanted to try something new.
I got some awesome help with the vac lines for installing my weber carb. I got the carb in and pretty sure everything is hooked up. In weber's instructions, they say that CJ's from 83 on have a "pulse air injection system" so two holes need to be drilled into the air filter top and two fittings installed and hoses connected to the air injection system. Has anybody done this and have pictures of the air injection system? anybody have info on this?
Thanks!!
The pulse air system works with the computer, and since the oem bbd carb is no longer connected, your emissions system can be removed. You should also have done the "John Nutter by-pass" to the ignition also, and add on the "Team Rush Upgrade" also.
Ok yea I was planning on doing the nutter by pass. Thanks!
