putting a 21 gallon fuel tank in a '75 CJ5?
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
I'm installing a 21 gallon fuel tank in my '75 CJ5 . Like most CJ projects what seems like it should be simple or a bolt on item in reality isn't. MY tank is supposed to fit and dimensionally I'm sure it does/will. The problem is, none of the parts supplied to attach the tank to the jeep fit. It could be the fact that the PO modified the rear of the frame. I thought I'd taken care of that issue by cutting off as much of his repair as possible and replacing it with jeep parts.
So, have you actually done this on an intermediate jeep? If you have experience, did you end up fabricating your own parts? It doesn't really look like a big deal, but it's always good to see how someone else tackled the same issue. Thanks.
