Quadratrac not engaging
somedude922
- Mckinney, TX
- 1979 CJ-7 Golden Eagle AMC 360, TH400, Quadratrac, AMC 20 and Dana 30 narrowtracs.
79 GM Turbo 400 , QT 1339, converted to part time. 4wd will not engage. I have vacuum at the switch, I can hear it when the switch is turned. When I pull the vacuum lines on the diaphragm, I have vacuum coming from the diaphragm on the t case. Am I supposed to have vacuum coming from the Transfer Case ? There are no vacuum leaks that I can see.
