Question about DUI distributor gear
I am in the process of installing a DUI distributor in my '79 CJ5 with the AMC 304 V8. I've searched the internet quite a bit and have read about all of the issues regarding hardened distributor gears on numerous HEI setups causing premature wear of the cam gear. It appears that DUI offers different options for the gear material but mine is stock with a steel gear. I'm hoping to hear from those of you who have installed DUI's. Did you replace any gears during installation, and if not did you come across any problems with premature wear of the cam gear in the engine? DUI seems to be top notch from what I've read and most of the issues on the internet seem to stem from other HEI clones but I still have my concerns. Thanks for any info.
