    To dismiss this notice
    click the top right X.
Question about roll bar for 85 CJ
firefyter
tx
85 CJ 7 Straight 6, currently being lifted and tuned.
Do they make an aftermarket roll bar that will bolt up to existing holes that is shaped like the wrangler type roll bars where you can put accessories like sound sysytem etc? If so who has them, thanks.
You have to buy the wrangler bars from what I have seen. Mounting dimensions are pretty much the same.
you can weld these in for the rear
Shop Jeeptubes.com Online!
the top right hand pic is of their roll bar stuff..
Or you can look for a family style roll bar from a YJ.
also they have a TJ style side cage tubes the should be able to be welded onto the main hoop and attach to the dash with another set of brackets.
Or if you google it you can find a whole ton of options including no weld systems that bolt up to your current main hoop.
$100.00
  50.0%
