Electrical QUESTION
Electrical QUESTION
Gtdoerinh
Enid OK
78 Cj5
Hello all!
I inherited my grandpas 78 CJ5 AMC 304 V8. I am in the process of fixing it up and have run into a snag. In my efforts to get the instruments back lights and tachometer working I seem to have messed up the wiring to the ignition coil. The jeep will start but then immediately dies.
The fun part is he was an electrician and instead of an ignition switch it has a kill switch and push button to start. Electrical is REALLY not my strong suit but I would love some tips on how I can get it running again.
The tachometer is still not reading so I’m unsure if this is connected to the issue or not.
:we:
1st test is to keep it running. The starter solenoid seams to functioning correctly as its feeding a full +12v to the coil and bypassing the ballast resistor when starting. To check this just feed +12v before the ballast and be sure it stays running.
Now for your crazy wiring. Your going to need a test light or preferably a meter. Do you have any of these to start diagnosing your issue?
You must login or register to view hidden content on this page.
