Questions about 78 CJ5 around the carb
jpeck71
- Media
- 3
- Chatham, IL
- 1978 CJ5 258 6cyl - 3sp T-150 - Dana20 TC - 2.5 inch spring lift - PO body lift - stock axles - 2bbl Intake and Holley 2300 carb - glasspack muffler - 31x10.5x15
First let me say that I have a service manual on order and should have it soon, but I thought I'd try to get some help on here. This is my 78 CJ5 . It was a farm vehicle for the last nearly 20 years and things have been disconnected and removed. The Jeep runs, but I'm trying to track down leaks and resolve things to get it running smoother.
This circled fitting below has vacuum on it and is completely open. I can close it off and plan to do that but I'm wondering what it is supposed to be connected to. Its the bottom side of the choke assembly.
This circled tube below is not connected to anything and does not appear to have any suction. I'm not really sure what it is for.
This picture is a little blurry but is of the driver's side of the carburetor just above the EGR valve. The fitting has two tubes coming out of it, one appears to be closed off, the other has vacuum on it. I'm not really sure what that is supposed to be connected to. Currently it has a hose attached that goes through the firewall and appears to be connected to the windshield washer nipple under the dash. That doesn't seem right.
This was connected and when I was trying to disconnect the hose to replace it the whole nipple popped out of the carburetor assembly. Is this normal? It slides back in the hole and I don't think I pulled with enough force to snap that nipple. I was just trying to slide the hose off. The hose connects to the top of the valve cover.
Again, sorry this is blurry, but its a hose that goes through the firewall right above the electrical and next to the brakes. This is the hose that connects to the carburetor and seems to connect to the washer under the dash. Is this supposed to be the washer fluid line? I don't have the washer fluid bottle or the fluid pump anymore.
Some of these things I might learn from my service manual but that won't be till the weekend.
Thanks for any help you can give.
