Questions for those who have spray lined?
firefyter
tx
85 CJ 7 Straight 6, currently being lifted and tuned.
What did you do around tranny cover? If you had body sealer that was dry cracked and removed did you replace it or just spray liner in its place or over it? There is a gap between the floor pan and the fender area where the roll bar was attached did you fill this with sealer or liner? Thanks.
I filled gaps with silicon before I did the bed liner. I also painted some rust converter in all the sheet metal seams before and silicon or bed liner. Do as much prep. as you can before application.
$45.00
  22.5%
