Quick Survey: Who runs a Weber Carb?
JeeperChris
Old Time Jeeper
- Michigan
- '79 CJ5, 258 I6, T150 w/Dana20, Dana30 front and AMC20 rear. My first Jeep! I'm looking forward to doing some minor upgrades and restoration while enjoying the ride.
A quick survey of how many here run a Weber carb, either the 32/36 or the 38/38, doesn't matter which one.
Second note to this: Do you run a stock type cold air intake or are you using the square Weber filter?
Third note: If you run a Weber filter, would you consider switching back to a cold air intake?
The reason I'm asking.... I currently have the Weber 32/36 with an adapter that lets me run the stock cold air intake. I like things better than stock. I see a simple way to make an adapter plate that will act as a "stub stack" and still let me run the cold air stock air cleaner and I'm wondering how many people might be interested in this as well... provided you are already running the Weber carb. This is not a quick thing so all I'm doing now is being curious about how many people run the Weber.
Thanks for your input.
