Misc. Rattle can paint job
Did you use a clear coat to? or was it a gloss or satin paint. it still looks good for 7 yrs.
Satin no clear coat just wax it once or twice a year. Here's what it looked like when it was fresh. I'm going to be repainting it in the coming months or early next year with real paint custom matches for classic military Jeeps in a single stage acrylicDid you use a clear coat to? or was it a gloss or satin paint. it still looks good for 7 yrs.
That came out nice, What spray paint did you use(Brand Name)I rattle-canned my old '77 CJ5 with semi-gloss. Even used the spray cans to "blend" in the flames using yellow, orange, and red colors by over spraying at an angle while the prior ones were still wet. Blue painters tape to mask it all off and an exacto knife to cut the tape on my sharpie marks for the flame pattern. Did use a clear coat afterward also.
View attachment 102221 View attachment 102222 View attachment 102223 View attachment 102224
View attachment 102225 View attachment 102226
Biggest thing you will run into with any compressor especially a smaller one will be moisture in the line unless you put in line dryers. Also 49 psi is pretty high for painting.Does anyone have an ideal of what size compressor and tank it would take to use a HVLP gun that uses 4.5 cfm @ 40psi? To paint my jeep
