Re-torque for safety!!!
hdgapeach
Old Time Jeeper
- Franklin, GA
- Right now, only one '76 CJ5. 304 with a three speed stick. Everything else is pretty much stock 'cept for a 4" suspension lift. Came to me with a back breakin' 4" suspension lift attached to a reverse shackle setup (Reversed the reverse shackle :dung: and now she rides like a Caddy!) Also posess a few 60s & 70s Mustangs and a couple of late 70's F150s 4X4s.
Little intro here: If you've read the under my "hdgapeach" in my few replies, you probably noticed I reversed my PO installed reverse shackle front end set up. That entailed cutting the buggered up welds that held all the spring and shackle hangers on the frame and replacing them with new hangers mounted in their stock location. I installed everything with new grade 8 hardware and no welds as of today (might add some after today!).
Now to the reason for the post: A few days ago I noticed a popping noise coming from the right front when I would turn into the drive way or make a turn at an intersection. Put CJ in the shop yesterday evening to have it ready to troubleshoot today after work. I got the significant other to turn the wheel while I looked at everything on the front end. Noticed the steering box bolts needed tightening (again!) so I gathered up an assortment of sizes sockets and wrenches and figured I might as well check all the "new" bolts. What I found was very surprising. There wasn't a single nut or bolt on the front end suspension and steering box mounting brackets that didn't tighten at least a half turn (half or more needed way more than half a turn)! I ended up re-torqueing every axle U-bolt, all shackle hanger bolts, all steering gear box bolts, bumper bolts (front & rear), etc. You name it. If I could get a wrench on it, it got tightened.
Save your own life tip for the day - If you replace any suspension or steering component, after about 1,000 miles go back and re-torque all fastening hardware!
