rear axle 20 amc seals
Fdpwr2a
NWMO
48 CJ2a ford I-6,T-90,D-18,Warn O/D pto winch
57 CJ5 buick v-6,SM420,D-18 Warn O/D
61 CJ5 buick turbo v-6 SM465,D300
77 CJ7 SBC 350 SM465,205
57 CJ5 Auburn trencher
Got a 20 rear that is leaking gear oil on the out ends. Got seals at the local FLAPS. Two seals for each side inner and outer. I thought the outer bearings run in gear oil? Do I need split the two piece axles? How do I set the preload on the outer bearings? I have some side to side play in bearings I think. Thanks Fdpwr2a
20 rear??
Be a good time to go with Moser 1-piece axles.
A FSM would be a good choice.
There is no 'pre-load'.
No on the bearing get'n gear oil-Pack it with grease.
