Rear axle
Rear axle
1799beast
Surprise
Hello everyone, I am new to this site so bare with me. I bought a 1977 CJ5 and the rear axle is off center about 1/8 of an inch. Does anyone here explain how I can center the axle to the correct position? Any help is appreciated. Thank you!:chug:
Things can get bent over the years and move around, I don't think you should worry about it. Did you measure from the locating holes on the spring pads to the center of the pinion gear?
Off center by 1/8"? Yes, how do you know?
I would not worry about 1/8". A
Some came from the factory 1" offset.
The spring bushings could be worn and it's leaning.
the big concern would be how the rear tracks behind the front wheels. yoke being a little off would be secondary. How did you determine that the axle was 1/8th off center?:cool:
X 2 on how did you figure that it was off set by 1/2 of an inch? If your measuring from your body make sure that the body is square on the frame.. Id lean more towards the body is off then the axle has moved.
