rear spring hanger
rear spring hanger
johnnyreb
Old Time Jeeper
tn
1980 cj5 258ci straight 6, 31x10.50's. Partial Teamrush iginition upgrade, MC 2150 Carb. 4.0 head swap, factory header. I call him "Eugene".
Dad's jeep when he raced in the 70's. Cj2 running gear, ford 300 cu in 6 cyl with 3 deuces. Fiberglass model T body and hand laid fiberglass hood. welded 5.38 gears and beer keg fuel tank. see avatar
Wife's: Black 04' Liberty with all the bells and whistles.
Quick question. How many bolts are suppose to attach the rear spring hanger to the frame on an 80 CJ5 ?
How many ya got?:D
There's 2 on my '85 CJ7 .
I got one per side and what looks like a bit of a stud on one side and a broke something on the other. I thought it seemed odd to only have one.
Sounds like you have a couple of busted off heads on each side that are broken just below the surface of the spring shackle hanger. If so you could remove those hangers and grab those broken off bolts with some vise grips to remove them. Check the female thread condition and replace all four with at least a grade 5 bolt. Good place for some Loctite also.
:eek:
Ck the frame for rust through--
I thinking it's a PO issue. I will tackle new bolts when it gets warmer.
