Rear upper shock mount replacement
Robs85cj7
Hey All,
I have an '85 CJ7 that the PO has welded a length of angle iron between the frame rails in the rear to make up for the fact that there are no factory upper mounts. I'd like to undo this and return it to near factory mounts but am running into problems finding rear mounts. I'm open to ideas for a replacement and can think outside the box. I was thinking the bolt on front upper mounts maybe? Ideas?
Thanks in advance,
Rob in CT
Thanks in advance,
Rob in CT
