removing leafs
removing leafs
dalefan88
Crazy Sr. Respected Jeeper
ada,oh
79 cj5 258, t150, dana 20 transfer case, dana 30 front, 20 rear,warn hubs,2.5" procomp lift,teamrush,msd box,mc2100 carb,hedman header,clifford intake,optima battery, ford shock towers.
i have read where some of you guys remove leafs in the spring pack to softin up the ride. my ? is which leafs do you remove. my pack has 5 leafs and all of them are different lengths. the shortest one on the bottom is the thickest.
I started with the bottom/smallest doing one at a time to see what happened and ended up removing 2 from the rear, keep in mind I do not have factory leafs but it softened the ride and lowered the rear approx.1/2" or so which was one of my goals.
not worried about if it lowers it any. its just i hear people say procomp lift ride hard and i have one and wanted to see if i took one out if it would softin up.
