Removing steering box - PS CJ7
Replacing the original box. Have pitman arm off (thanks to suggestions here). Manual says to disconnect PS lines - I can't see them and assume I need to drop the box to get to them - correct?
Also, do I need to disconnect the shaft at the top? I removed the bolt below the boot. Will the spline gear slide out or am I going to have to pry?
I'm ready to try the three bolts through the frame. I have a jack under the frame to release spring pressure. I'm hoping I can support the box and drop it down when the last bolt comes out. Then remove the hoses and just drain the fluid then.
Any advice/corrections greatly appreciated.
Thanks,
Barry
Thanks,
Barry
