Removing Stubborn Pitman Arm
JeepDave
I'm having a heck of a time removing my Pitman Arm. I've watched several YouTube videos and everyone uses air tools to zip it right off. Me on the other hand, I'm tightening the Pitman Arm screw and having to bang on the front of the Pitman Arm with a 3lbs sledge. I sprayed a bunch of bolt breaker on the splines in hopes of adding a little more lube but that hasn't helped.
Also, any point in removing the castle nut to allow for a little more wiggle room when pulling off the arm or will the grease bearing flex enough so as to allow the arm to drop below the threads? I already removed the castle nut but don't want to do more work than I have to...
Any thoughts, tricks or any other advice welcome. Thanks! JD
