Replace clock with water temp gauge
nivensid
Marshville, NC
'86 CJ7, 4.2L, T5, D300
Can someone tell me what size gauge is needed to fit in the dash to replace the clock? I know the oil and volts gauge is 2". Merry Cristmas everyone. 1986 CJ7
If you don't have one. That would be a good spot for a tach.
I put a vacuum gage in that hole, left of column. Once you start to look you may find that the selection of gages that are available to fit in that hole are a bit Limited .
https://m.summitracing.com/parts/sww-82409-72
Ordered this gauge to replace the clock. My stock water temp gauge does not work so i need this. My stock oil.pressure gauge was reading 0 at idle and 20 lbs at 55 mph. Could have fixed it but never would have trusted it. Now have mechanical gauge 60 lbs cold idle and 30 lbs at running temp.n
I have that same gauge. The temp probe is large and kinda long.
Post'n pics is above my 'level'.
