Replacement YJ springs
Az84cj7
AZ
84 cj7 Inline 6, mopar fuel injection , T5 trans, dana 300, Dana 44's
I did a YJ spring over conversion on my CJ7 . I used a stock set of YJ springs. The springs are a little tired. Does anyone know of a quality replacement spring that has no or no more than an inch of lift?
Ive seen them on 4wd.com, quadratec, etc. in stock height.
Well I just did a search thinking for sure one of the name brands makes replacement springs but 2" seems to be the minimum unless you get the no name replacement ones:cool:
I would recommend a spring that was designed for the SOA conversion. Deaver Spring in CA. and Alcan Spring in Colo. are two excellent sources.
